I've installed a Winfast DV200 card to capture my analoge video
The card came with capturing software (WinFast PVR) - If anyone else has captured analoge with this card I'd appreciate any advice as to whether I am better off using VirtualDub etc or the WinFast PVR
In my experience I would use Winfast. I had a lot of trouble capturing with Virtual Dub. The results were basically crap, but others swear by it.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
The trouble with WinfastPVR is you have no indication of whether you're dropping frames or not. I'd go with VirtualVCR, myself.
That's true. I actually capture video thru my DV camera with Windv( or power vcr, depending on quality requirements) which I think is a zillion times better.
Trying to select PVR software for my capture card.
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 14th Apr 2010, 19:03 -
winfast PVR -avi
By sg999 in forum Capturing and VCRReplies: 0Last Post: 12th Dec 2008, 13:13 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Winfast PVR Interlace capturing, is it possible?
By quanz in forum Capturing and VCRReplies: 2Last Post: 11th Jun 2007, 22:46
