i need to knwo what software that i can use to record this mpg clip taht came with seom subtitles, i thought i could do it with nero but seems like im wrong . can someone please inform me as to how to get this done if its possible pleaaaaseeee
Hi!
If your mpeg file contains subtitles, then you can burn it to a CD or DVD using Nero or some other burning software.
// Znooky -
i have nero 6 but i dont really understand how to do it whenever i take the .sub or the .idx files into the record section of the vcd screen it says unrecognized format , what do i need to do cus i have serached the site and there is nothing in reference to doing this can someone point me in the right direction or maybe tell me whats the easies way or software to have this done ????
Hi!
First you have to multiplex your subs with your SVCD-File. After that's done you can then use Nero or some other burning software to burn the SVCD-File.
Look in this guide http://www.how-to-convert.com/ask_us/a7042003.htm
// Znooky -
Problem is, not many players support selectable SVCD subs. Your best bet is to reencode the mpg and fit it with permanent subs. Use the mpeg2 enabled version of VirtualDub and the subtitler filter and frame serve to the encoder.
/Mats -
Im actually trying to burn it as a vcd rather thatn a svcd, but i dont understand how to get the subs to stick to the movie file, when i go to record it. Each time i take the movie file and put it in the recorder screen and that goes fine but when i try to use the .sub or the .idx file it says unrecognized so what do i have to do to stick the subs into the movie itslef to just go ahead and mke the vcd ???
Ok, but VCD doesn't support selectable subtitles, as SVCD does. However, you can add permanent subtitles to you VCD file, but then they will always be visible every time you watch your VCD.
There's a lot of guides of how you can do this. Take a look in some of these guides.
https://www.videohelp.com/guides.php?howtoselect=5;20#262
https://www.videohelp.com/forum/userguides/153058.php
https://www.videohelp.com/forum/userguides/87065.php
https://www.videohelp.com/srtsubsvirtual.htm
// Znooky
Audio and subtitles in mpg files...
By kdolan1973 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 19th Aug 2010, 15:17 -
recording a mpg file right to dvd recorder
By abrand88 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Feb 2009, 18:47 -
vob to mpg with subtitles included
By brywkeo in forum DVD RippingReplies: 7Last Post: 10th Mar 2008, 16:44 -
DVD to MPG w/subtitles, possible?
By OmfgZerg in forum DVD RippingReplies: 10Last Post: 23rd Feb 2008, 23:42 -
Add subtitles to an .MPG video
By Nilfennasion in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2007, 08:05
