I tired doing this..STEP BY STEP
https://www.videohelp.com/srtsubsvirtual.htm
I got the Illegal Stream message
was suggested i do this
https://www.videohelp.com/virtualdubframeserve#problems
and still having problems..i followed it step by step on numerous tries. Are there any other solutions that could work? I use Windows XP i do have ME running on my other drive..could that change the solution..I dont think its a OS issue but one never knows.
Are you using Virtual Dub mod, or another version?
Hello. -
Thanks man..I was using the regular VDUB..hopefully this Vdub link helps the chaos
