In the past few days, I have backed up a number of DVDs that were RSDL, using DVDShrink. In most cases, simply removing all the extra features and unnecessary subtitles or soundtracks was "enough" to keep the video from turning into a blocky mess. Some discs even come with so many additional features on them that the main film will fit into less than 4.35GB without any soundtracks or subtitles removed. Not that I don't remove them. Nearly all PAL discs come with so many subtitles and dubs that I'd never use, it's annoying. I've seen some discs where one can save over two gigabytes by removing dubs.
However, there are some cases where the discs are RSDL, and not just to fit unnecessary dubs or subtitles. Inevitably, one must recompress the video in order to make it fit on a 4.7GB disc. The problem, of course, is what threshhold one considers "safe" to compress the video at. While I've attained some pleasing results with as little as 63% of the data size of the original, what would really be considered the furthest one can compress the video data?
on most movies that i use dvd shrink on, i dont compress more than 30% (70% left). on some really good movies that i really like, i will get rid of everything, and just do a movie only dvd, and try not to compress it at all if possible
I was playing the other month with getting a dvd down to one or two mindvd (dvd format on cdr).
It took 4 shrinks of maximum allowed (about 58%) each time.
(I wish shrink would let me go right down to 20%!!)
The resulting 2 cdr's had video with 5.1 sound (full dvd size, dvd coding, not svcd or vcd) AND the quality was better than vcd, about the same as a good svcd.
I'd say it depends on the movie, but try it (use a cdrw - erase it if it don't work, burn to cdr if it does).|
Meeow!
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 08:57 -
convert .mkv from level @5.1 to level @4.1
By florinus in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2010, 16:33 -
safe/sure video format
By elmuz in forum Video ConversionReplies: 4Last Post: 18th May 2010, 11:49 -
Is it safe to sell our free cell-phones? Also, is it safe to BUY?
By siratfus in forum Off topicReplies: 3Last Post: 12th Dec 2009, 16:30 -
TV Safe Colors ?
By Mike99 in forum Authoring (DVD)Replies: 31Last Post: 13th Nov 2008, 04:01
