As some of you guys might know I am applying to Penn State. PSU requires their students to take foreign language in their first 2 years. Well I want to learn japanese(I like the way the language sounds, and theres a strong relationship between the tech industries there and I am going into tech).
What is the best book to learn with? I want to get sort of a jump start over the summer so that way if I am accepted I have at least something to start out with.
A bird in the hand is worth a foot in the tush-Kelly Bundy
This series is very good "Just Listen 'N Learn Japanese"
Can be bought at Amazon or local bookstore (if in stock) and comes with book and audio.... Which is good because they use natives where it helps with better pronunciation. Very practical too...Even a fool can be wise, all he has to do is keep his mouth shut -
Some of the language courses you can buy in stores have ONE good CD in them out of the set. For instance...the Instant Immersion sets are useless unless you have learned SOME of the language on your own.
However there is ONE disc in those sets that is VERY good because it is from a different company...
The company is called Rosetta Stone. I am learning German with this computer CD set. The CD course alone will not get you a full and working knowledge of a new language but out of all of the ones I have purchased....Rosetta Stone is the one that has helped the most.
www.rosettastone.com
Believe it or not....Ebay is probably where you'll find the largest selection of Rosetta Stone packages. I've never seen them in stores. -
You just need to learn two words......Saki Bomb.
Not sure how that will be translated into those funky little symbols but just learn it.
HatzLoves the funeral of hearts..... -
The best book to start on for beginners is a book called "Japanese for Buy People"Originally Posted by devinemi83
When learning the language, you gotta do like this: Learn how to make the sounds, there's nothing worse than speaking with a terrible foriegn accent. Next, learn the basic grammar everyday words, and basic phrases. While you are learning the easy stuff, also do the basic characters of hiragana and katakana. FORGET about the kanji until way way later. If you have any questions PM...
There's Sake Bomber for ya HatzSmile
Smile -
Go to Japan and learn. Another hint, do you know of any Japanese nationals in the U.S. would be able to teach?
I visited Tokyo a couple times and not enough time to learn though.I am a computer and movie addict
make subtitle for learning video
By seyyed in forum SubtitleReplies: 1Last Post: 2nd Oct 2011, 08:06 -
Why can I get a low cost learning remote ?
By SingSing in forum Newbie / General discussionsReplies: 7Last Post: 27th Mar 2010, 19:35 -
Newbie question about learning
By Tundra Trout in forum Newbie / General discussionsReplies: 4Last Post: 22nd Aug 2008, 17:41 -
Learning how to use WAX?
By terrypin in forum Newbie / General discussionsReplies: 4Last Post: 17th Aug 2007, 12:59 -
ebook for Learning VirtualDub?
By mlong30 in forum EditingReplies: 2Last Post: 15th Jun 2007, 20:02
