  1. Hey all, I just purchased QT Pro to edit and convert .mov files to burn onto dvd. Problem is - only half of my .mov files are viewable now. Some work fine and others show a blank white screen while only audio plays. I either get a message that says "QT was not able to d/l software to display this movie file" or "the required compressor could not be found". I previously had QTalternative installed and ALL my .mov files played perfectly. I went to Apple's website and got the runaround over and over again before giving up. Any ideas how to fix this? I'm running WinXP if that helps.
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    the last builds of qt pro are a royal screwup ..
    i think its apple's revenge
    lots of people having problems .
  3. Well, I just downloaded an older version (5.0). Uninstalled 6.5 and installed the 5.0 and it works perfectly. Before I did this, I emailed Apple and got no response. I posted this problem on two different forums and got the same answer (that it's the software). I guess this proved everybody right. Hey, old or new software, it doesn't matter to me just as long as it works (and I know that I'm not out $30).
  4. Member teegee420's Avatar
    Dec 2003
    Southern California
    Apple should change their slogan to "Think again".
    :P
