    Jan 2004
    NearBrussels Thats Europe
    Hi could someone please suggest a tool to rip the audio out of mpg's to WAV's or MP3's
    I know Tmpgnc can but I can't use MP2's. My final destination is CDA for the car CD player.
    Thanks.
  2. ffmpegGUI should be able to take you from MP2 to MP3. So, demux using TMPGEnc and use ffmpegGUI to take it to MP3.
    If it's only to go onto a car CD, make the target MP3 as high a bitrate as possible. Although the audio is taken back to LPCM for CD-Audio, it means you don't get two doses of compression crap.
    Hope this helps,
    Cobra
    Jan 2004
    ffmpegui does AC3 or MP2 which is useless to me. Like I said I need MP3 or WAV.
    thanks
  4. If you look at the comversions the tool is capable of making, you'll see it can apparently do all of those. That is what I based my advice on. Unfortunately, it was incorrect.
    Cobra
  5. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Honk! Honk! ???
    That's a new one! :P
    DVD2AVI can decode to a PCM WAV file. Just rip the DVD in file mode and load the VOB files into DVD2AVI
    Remember that CD audio is 16-bit Stereo 44.1k not 48k
    - John "FulciLives" Coleman
  6. Guest
    Guest
    I love this program. It lets u record to wav/mp3 from anything going thru your soundcard. i.e.-dvd/cd playing on your pc,pc tv,streaming audio/video. Anything u can hear on your pc speakers.
    http://www.mp3do.com/soundrecorderxp.html
    u can download the trial version that only lets u record 1 min files.$30 to buy. I find it well worth it.
  7. VirtualDub to save the wav and dBPowerAmp to convert to mp3. Both FREE
