  1. Member Tool Man's Avatar
    N. Ireland
    Just bought a Wi-Fi router and it's driving me crazy. It's a US Robotics wireless turbo (USR8054). I have NTL 600K cable broadband, and I wanted to share it with my desktop and my Acer laptop. The desktop works fine (10/100 cable to router), but the laptop won't connect. It detects the wirless network, and claims to connect with 'excellent' signal strength, but I can't get it to aquire an IP address. I left it connected for about half an hour, and nothing. Network properties says 1,200k sent, 260K recieved, and IP <unavailable>, although the router shows on my desktop computer that the Acer is connected and has an IP address.
    Any network experts that can help me?
    Thanks.
    Tool Man.
    We'll be right back after these messages from Binford!
  2. Anonymous
    Guest
    check to make sure wap encryption and mac filtering are not active.
    also try resetting the base
  3. Member Tool Man's Avatar
    N. Ireland
    Thanks, I got it sorted. The problem was with the network bridge. So I removed it, and it obtained an IP straight away. Strange. What affect will that have? What do I need the bridge for?
    Thanks.
  4. I believe the "Bridge" mode is used for linking 2 Wifi Routers or WAP's together. Typically used to extend WiFi service coverage area or join 2 wireless networks or wired networks via a wireless link.
  5. Member Tool Man's Avatar
    N. Ireland
    Thanks. I got the internet sharing OK. Both computers can get online, but I can't share files between them. I created a workgroup, and ran the network setup wizard on both machines using the same workgroup name, but I can't access files on another PC. Shared Doc's only shows the PC I'm using, although the other PC shows in 'workgroup computers' but I can't access them. Any ideas?
    Thanks again guys.
  6. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    jump into my computer, click properties of the drive you wanna share. there should be a sharing tab - tell it you want to share. you may need to restart, and then you're done.
