Hello,
I am trying to burn the X-men dvd but when i am in Clonedvd and AnyDVD and i open it i get a message VIDEO_TS not found, but when i explore the cd the folder is there. I cannot go to the next step to be able to burn. Whats the problem ? What should i do??
I have one more question i got a copy of dvd which i can play normally on the computer but when i try to play it on the standalone dvd it doesnt work.
Thx
JKoniak
If it was me, I would try dvdshrink or DVD decrypter (both free) just to see what happens.
Q 2 This is fairly normal. Many standalone players will not play dvdr for various reasons."Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
I agree , also is your standalone player compatible with the media you are using (check your player in the DVD Player section) if it is compatible try burning slower , if that doesn't work try a different brand.
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 19:01 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12 -
Power DVD Copy Problem
By Tel in forum Authoring (DVD)Replies: 3Last Post: 8th Aug 2007, 16:51 -
dvd copy problem
By ht0160 in forum DVD RippingReplies: 10Last Post: 1st Jul 2007, 17:31
