I am burning avi's on to dvd & cannot get a DVD-R to work
I am converting from avi to mpeg with TMPGEnc, formatting to dvd standard with TMPGEnc Dvd author and burning with Nero 6.
I always burn on to a DVD-RW first in case something's not right, then when I confirm everything looks ok, I burn to DVD-R.
However, less than 50% of the DVD-R's work - they simply do not play on my dvd player.
I am using Maxell DVD-RW 4.7GB (version 1.1 DRW47.1P - yellow disc/box) and Maxell DVD-R 4.7 GB (DR-V47.MEL.1P - green box/disc)
I leave Nero open between -RW & -R burns & change nothing! - so in theory, the _r should work, if the -RW is verified ok.
My DVD player is a multi region Toshiba SD510e
DVD burner is a Pioneer A04, PC is a Dell p4, 3.0gig etc.etc.
Can anybody hel please - it's getting very frustrating & expensive making coasters!
Fec
Try it on a different DVD player (a friend's, family member's player). I suspect that you have a picky DVD player that just doesn't like your discs. You can also try a different brand of media and see if it works out better.
Pioneer DVR-530H:Cannot burn to DVD-Rs, works with DVD-RWs
By boba_dk in forum DVD & Blu-ray RecordersReplies: 33Last Post: 31st Jul 2015, 13:24 -
Dual Layer burn issue with TMPGEnc Authoring Works 4
By am_dew in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2012, 09:36 -
DVD works on DVD player but not recognised in laptop
By rline101 in forum DVD RippingReplies: 6Last Post: 11th Oct 2010, 17:09 -
Device Capture - USB, Works With PAL / NTSC, Works with VirtualDub/VCR
By Drazick in forum Capturing and VCRReplies: 0Last Post: 7th Aug 2010, 19:27 -
TMPGEnc DVD Authoring Works 4 DVD+r space problem
By gigaslackr in forum Authoring (DVD)Replies: 1Last Post: 28th Dec 2009, 14:43
