hello,i have made dozens of SVCD's,so i know a little,lol.
here is my problem: i captured a VHS movie using virtualdub,i used huffy.then i used TMPgn to encode it,ok i am using the software that came with my dvd burner,its pinnacle studio 8,i am using that to add titles/subtitles/effects,etc. i am also using the pinnacle to "burn" the dvd.after spending hours thru all this the burned dvd plays great on my PC(powerdvd) but when i want to view on the TV my home dvd player says"no disc"i have a Apex dvd player(plays all formats) the Apex played all the SVCD's i made,what am i doing wrong?,i am using pretty much the default settings in virualdub and TMPgn.i am thinking the pinnacle studio software is junk?,can someone point me in the right direction.thanx. 8)
Use IMGTools Classic to make an ISO out of your VIDEO_TS folder. then burn the ISO with DVD Decryptor. If that one works then the problem is in the burn.
you don't mention what dvd media your using, could be an issue or have you used the media sucessfully b4?
THANX for the replies!!,ok,i am using DVD-R media(inexpensive),and also when i try to play the "burned" dvd in my Liteon dvd rom it says"media not supported" it only plays back in the dvd burner,i am no stranger in messing with stuff to"get it to work",lol.but i am stumped?,all i need is a little info or point me in right direction,to try. i am thinking maybe i need to spend some $$ for a decent dvd prog.? ,thanx.
I dont use Pinnacle studio, but the fact that your disk plays back only in your writer sounds very much like the disk has not been finalised. Does pinnacle give you such an option?
It could be media. More often than not the reasons I have found for a disk not to work is:-
1. Ignoring an error message during build or write.
2. Poor/bad media.
Good luck.TOMMO -
,pinnacle doesnt have options as to finalizing,you have some options as to video quality,audio,etc. but no finalizing?,i bet thats the problem,ok off to waste another disc?.lol.thanx for reply.
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 08:47 -
making DVD
By narcissus in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 01:18 -
making DVD
By narcissus in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Jul 2008, 20:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 13:03 -
Making a DVD
By Lord Balthazar in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 09:10
