  1. Ok So I'm Backing up Swordfish and the actual movie went great. Now I'm trying to get the trailers and alternet endings which are in their own set of Vob Files. When I load the vob files into DVD2AVI it will get the video track ready to convert but won't pull an audio track. Is this because it's a special feature and not the movie. Or do you have another suggestion. If this won't work is there another proggy I can use to do this that will work with TMPGEnc. Thanks
    Me
  2. i'm assuming you used dvd2avi to cut out the part of the menu/trailer or whatever you wanted? i know when i was ripping some menus, they were all in one vob, like, one continuous vid file and i had to manually cut wiht dvd2avi.
    but anyways, are you sure that the audio isn't set to none? also, you may have chosen the wrong audio track. try a couple different tracks (or check the .ifo file from the ripped vob for which audio track you want).
  3. Thanks alot that did it for me.
