Which tools should i use.
You will need to convert the .avi files to .mpg. I use TMGPEnc Plus.
You will need to author the .mpg to DVD (menus, chapters, etc.). I use TMGPEnc DVD Author.
You will need to burn the authored files to DVD. I use Nero.
Read the Tools, Useful Software section on the left and pick out the tools you want. Read what other people have to say about them.
Also read What is DVD at the top left and read the guides that use the software you have chosen.
Read, read, read!
When you bump into a problem, come back here and ask for help.
Don't squat with yer spurs on. -
Depends on what kind of AVI's. Start with TMPGEnc encoder and read the guides, specifically under 'Convert'. You will also have to author the resulting MPG file with a program like TMPGEnc DVD Author. If the AVI's are DIVX, then you have extra steps depending on the format.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42 -
Convert HDTV ts files to DVD mpeg or Avi
By kenmo in forum Video ConversionReplies: 5Last Post: 6th Nov 2011, 10:17 -
how to convert two avi files into dvd
By justmehere in forum Video ConversionReplies: 4Last Post: 22nd Jan 2009, 20:08 -
convert avi files to dvd
By crashstorm in forum Newbie / General discussionsReplies: 5Last Post: 11th Dec 2007, 16:44 -
Convert AVI files to DVD
By gbc410 in forum Authoring (DVD)Replies: 4Last Post: 1st Aug 2007, 02:02
