I have a MOV file that will open in Quicktime but nothing else.I downloaded TMPGE and tried to convert it over to DVD and all I get is "Illegal file".
How does this work? Why is it so hard to do?
I really don't want to go and buy a MAC which probally the easist thing to do.
Windows suck.
Thanks for the help.
Install the TMPGEnc MOV Plugin and try again with TMPGEnc.
Still gives me "illegal file" thing.
Sorry for be ignorant, but I'm learning! Still pretty green at this stuff.
Thanks for being patient. -
You're sure you put the plugin in the TMPGEnc folder? If so, try using Mainconcept MPEG Encoder. If that gives you an error too there's not much else you can do. Make sure your installation of Quicktime is up to date.
Originally Posted by Tweakerxp
Ripping a .MOV file from a DVD-R?
By Reign20 in forum DVD RippingReplies: 1Last Post: 12th Apr 2011, 04:31 -
Is there a way to put a 'whole' DVD into a converted file?
By reapur in forum DVD RippingReplies: 5Last Post: 6th Feb 2011, 20:33 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
Creating avchd dvd from .mov file
By Mike L:isi in forum Authoring (Blu-ray)Replies: 16Last Post: 6th Aug 2009, 10:14 -
how do i put srt file in dvd lab pro?
By oilpourer in forum Authoring (DVD)Replies: 6Last Post: 1st Jul 2007, 18:20
