is it possible to use an exist dvd menu
for example, i have the origenal dvd of the matrix well i like the menu and the effects and so on
now i want to use that menu to make my own dvd only i want to replace the pictures with my own pictures and i want to replace the matrix movie with my own captured holiday movie
so i just want only the movie imported into dvd-lab so i can edit it
is this possible...??
Everything is possible
just depends how much resources you wanna throw at it -
well you said it's possible well i've look almost everywhere i can find bout DVD menu but can't find anything that say's about use exist DVD menu
does anyone know how to do this or know a guide what i can follow?? -
i want to use an origenal DVD menu
example i want to use THE MATRIX menu but replace the pictures and movies -
I know, you mentioned that. But if you replace the pictures and the movie what's left? The menu structure is easy to recreate. You can do it with DVD-Lab. What's fancy about the Matrix menus are the videos. If you can make fancy videos from your holiday collection you can make similar menus as the Matrix ones. For this you need a good video editing tool. DVD-Lab won't do.
The matrix DVD contains few motion menus (root, language/subtitles and several scene selection menus) and many really well done transition videos which connect nicely with the menus. The menu loops are also very well thought of. That's the trick.
Does a simple AVCHD authoring program exist like DVD programs?
By Killer3737 in forum Authoring (Blu-ray)Replies: 4Last Post: 29th Sep 2011, 11:16 -
Does such a monitor exist?
By A Traveller in forum Media Center PC / MediaCentersReplies: 13Last Post: 9th Sep 2009, 18:45 -
Does This Product Exist?
By Anakin in forum DVD & Blu-ray RecordersReplies: 5Last Post: 26th Dec 2008, 10:09 -
CAMERA DVD to PC DON"T EXIST
By ginx10k in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 14th Aug 2008, 04:29 -
AVI to DVD to Burn - All-In-One App Exist?
By quantass in forum Authoring (DVD)Replies: 11Last Post: 2nd Jul 2007, 21:20
