can anyone shed some light on the pros and cons of using analysis alone or using deep analysis...thanks in advance.
I can't blind you with the technicalities but suffice to say I've tried both on the same movie and there is a significant improvement using DA.
Put simply, DA is working harder than A and as a result improves the quality; it does exactly what it says on the tin.
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I assume that DVDShrink is working by looking at each individual frame and applying a certain amount of data loss to that frame. This should reduce the overall filesize. Maybe deep analysis lets it know which scenes it can save lots on, and which it can't.
I don't know how it all works, but it does. Deep analysis definitely yields better results, for an extra 30 minutes work. I'd say it's worth it.
Cobra -
analysis is a brief one pass scan of the movie. it isn't going to get you good results at all for high compression. DA is a 2 pass in depth scan that determines where best to adjust bitrate in the movie.
analysis: more than 16 cores pointless
By deadrats in forum ComputerReplies: 49Last Post: 18th Dec 2008, 09:53 -
Software for analysis CD/DVD
By grzegorz in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 21:14 -
"DVDshrink - Vista where is Application Data Analysis files located?
By mn072065 in forum DVD RippingReplies: 2Last Post: 24th Feb 2008, 18:43 -
AutoGK Analysis, how good is it?
By hotwings in forum DVD RippingReplies: 4Last Post: 30th Jun 2007, 14:34 -
Audio analysis software needed
By Nelson37 in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2007, 00:17
