Just bought a new Sony DCRHC20 MiniDV. First digital video I own. Problem is when I transfer to PC video looks fuzzy. Square kinda pixels.
I have a Emachines T2542 Celeron 2.5GHZ 120GB HD 1GB memory XP. I transferred the video using a generic firewire 1394a card(BestPorts?).
When I view the video on the LCD it looks fine. Viewed on the TV looks fine. When viewed in premier in the small vindow it looks fine. When I play back after capturing in premiere looks fuzzy. When I play the captured avi file in windows movie player looks ok in small window but not full screen. I have analog tapes that look better. I am using the default settings in premiere, (settings viewer - capture - dv/ieee, compressor, microsoft DV(NTSC) - project capture microsoft DV AVI - export capture microsoft AVI compressor cinepak codec by radius. Have an intel extreme graphics card 845GV. I tried a couple things I read in posts. I used dvio, installed pvdcodec. I tried on my 2000 machine usning ATI all in wonder card. Tried best quality MPEG2 and the captured video ran too fast. The best quality I got was at quarter Mpeg quality. That is what I used for my analog tapes. I thought I should get a better quality capture from DV? When capturing in premiere in the project setting window I tried to select video for windows but it says it can not connect to capture driver. Maybe I don't have something installed correctly? Maybe I am just expecting too much? I've been looking through posts for the last 3 days. Sent Sony support email - useless.
Thanks for any help.
Sorry, I may have missed it but have you encoded to mpeg2 yet?
You have it as DV on your PC and if you haven't encoded or burnt to a DVDr you may simply be experiencing interlacing.
Suggest you encode to mpeg2 with the trial of TMPGEnc Plus at 720 x whatever (576 for me, PAL) at 8000CBR and then author to a DVD.
Then see how it looks on your standalone DVD player.
Will
EDIT: Hang on, you're not 'capturing' from your camcorder on the fly to mpeg2 are you?tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
I think it may be your camera. Can you borrow a friend's DV camera and transfer DV to your sys tem with it?
Hello. -
I changed the CBR to 8000 and created and mpg2. I then created a DVD with both the original AVI and the new mpg2 files. When I play them on my DVD they both look good.
I can't understand why it doesn't look good on the computer? -
...and if you haven't encoded or burnt to a DVDr you may simply be experiencing interlacing.Originally Posted by Will Hay
Look up interlacing the glossary.
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Read about interlacing on 100fps.com. I tried to use tmpgenc, encode as non-interlaced. Didn't work. Still blurry but only when I play in full screen. When the video is small it looks fine. I had a friend bring over their DV camera with the same results. So it's not the camera. Tried a whole bunch of different settings in tmpgenc. I can make the video worse but not better. The video doesn't look as bad as some of the other pictures I saw in the other forums here. I will try and do a screen capture of the small movie and large movie if would give you a better idea of what I am seeing?
Sony HDR-XR500 - Losing quality during the export process
By amnono in forum EditingReplies: 8Last Post: 6th Aug 2010, 09:37 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00 -
sony hdr-sr10 to blu ray quality help
By mrdinh in forum MacReplies: 4Last Post: 16th Jun 2009, 04:31 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38
