Results 1 to 9 of 9
    Mar 2004
    Houston, TX
    How many of you guys use it? Are there any flaws or disadvantages with the program? I usally use Decryptor to rip, SHrink to encode, and copy to DVD to burn. Can I use ANYDVD and Shrink or do I have use CloneDVD with ANYDVD? let me know what you guys prefer.
  2. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    AnyDVD simply makes the dvd region free and copy protection free. If you run AnyDVD and rip with dvd decrypter, you will notice that dvd decrypter reads the dvd as copy protection free. You can use it with anything.
    "Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
    Mar 2004
    Houston, TX
    I still need to use Decryptor with ANYDVD?
  4. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    No, you don't have to, but if it's running then it will do no harm.
  5. Member tweedledee's Avatar
    Oct 2002
    Melbourne Australia
    Maybe this will make it clearer. One picture shows Anydvd enabled, the other shows disabled when about to rip with dvd decrypter.
  6. A point i'd like to make is that DVD Shrink is perfectly capable of decrypting a dvd on it's own. You don't need to use DVD Decrypter or AnyDVD with it at all.
    RealaT Bytes, but that's what life is.
  7. i would like to ad
    that if you use anydvd with dvdshrink not only you don't need to use dvdcripter .as well you cut your ripping time almost to half time
    use it ...
    Roxxan
    TO BE OR NOT TO BE IS THE SPEED YOU BURN
  8. But you DON'T need AnyDVD if you're using DVD Shrink!!
    It can decrypt dvds on it's own
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    i use dvd43.
