This may be slightly off topic but I cannot get the playback from Real Player or Windows Media Player to be playable through the S-Video output of the computer graphics card. I thought I finally had a way to burn these oddball video formats to a DVD through the input of my Panasonic E-50 and everything else on the computer screen is visible but the playback. It might not be possible but I thought I would check it out first. The reason I am trying this instead of converting the files (so far only possible with RMs) is that the quality stinks and the sound winds up out of synch after conversion.
Still a few bugs in the system...
What video card are you using? Some cannot display the overlay field out to tv.. this overlay field is what is used to display TV, DVD, and most movie formats on a computer.
An easy way to tell if the overlay is the problem, is the area where the video is playing showing up as solid pink or green on the tv? -
My card is in a laptop and is a Radeon 340M. The color is not pink and I would not say green either unless it is very light. Assuming you are correct is there any way around it or should I try another computer; my other card is a Nvidia 5700 Ultra?
Thanks much.Still a few bugs in the system...
Recording FLV using real player does not start in some video files
By 1234567 in forum ComputerReplies: 5Last Post: 5th Feb 2012, 17:14 -
Video File (Suspected Real Player)
By Keycool1 in forum Video ConversionReplies: 2Last Post: 16th Feb 2011, 21:55 -
Real-time Video Effects Media Player
By deathclaw in forum ComputerReplies: 6Last Post: 11th Feb 2010, 06:26 -
Real Player video gives blackscreen on TV Out for Acer laptop
By NG in forum Media Center PC / MediaCentersReplies: 5Last Post: 11th Dec 2007, 13:31 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
