BTW, data rate is 4000. I'm capturing with Studio DC 10 Plus. My hard disc supports now up to 10164 (write) and 8598 (read) data rate. Can I fix the "dropped frames" thing by changing the data rate? PLEASE HELP!!! Thanks))))))
Mariano
are the drops in clusters or single frames gradually over time? if the latter i'd suspect the clock stability of your soundcard. less than 1 dropped frames per 1000 is ideal, although 1 or 2 is not bad
thanks for your help
I truly don't know if they are in clusters or single frames.... AVI_IO says just "drop: " and the number of frames. I'll check out what you said anyway
Thanks again
Mariano
problem on captured VHS frames
By stefangs in forum Capturing and VCRReplies: 13Last Post: 5th Mar 2012, 02:38 -
Virtualdub VCR capture no dropped frames but 5400 inserted frames in 1 hour
By suloku in forum Capturing and VCRReplies: 12Last Post: 17th Aug 2011, 23:33 -
Finding dropped frames in captured avi
By vhelp in forum EditingReplies: 4Last Post: 14th Jun 2010, 06:24 -
Captured AVI frames broken/split/badly aligned
By cyclometric in forum Video ConversionReplies: 3Last Post: 25th Sep 2008, 08:50 -
Problem with some captured frames
By bmbsa in forum Capturing and VCRReplies: 3Last Post: 24th Aug 2008, 21:33
