I am trying to convert mpeg and avi files to mpeg2. I am using Virtual Dub and TMPGEnc Plus to do this. I am using Virtualdub to extract the audio to a wav file and then using TMPGEnc to combine the original file and wav file into an mpeg2 file.
I have found that for some files the audio gets out of sync with the video. It seems to just be MPEG files with a certain codec, but I am unsure of what codec it is. I have used Gspot before to see what codec an avi file uses, but it doesn't do mpegs. Is there a similar program for mpegs?
Thanks,
Chris
only tmpgenc writes data to the coment section of a mpeg file -- otherwise its difficult to say which encoder did the encoding ..
i think you don't really mean mpeg2 codec"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
XVID, DIVX are not mpeg2
vcd is mpeg1
as for if its a svcd or a dvd or something else -- you just look at the resolution and bit rate and you can tell ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Try Video ToolBox, it works well with MPG's, similar to Gspot or AVIcodec.
Some help needed, Trying to find the best approach to edit MPEG
By chadwill in forum EditingReplies: 14Last Post: 21st Aug 2009, 07:45 -
Missing Codec(s) ... How to find/install/use?
By CaptainChaos in forum Video ConversionReplies: 7Last Post: 18th Oct 2007, 03:47 -
ConvertXtoDVD does it find optimal mpeg bitrate for you?
By supaguy in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2007, 16:13 -
Can't work with or find codec for "OpenDivx 4" files
By Lolipop Jones in forum Video ConversionReplies: 5Last Post: 14th Jun 2007, 16:43 -
How to find the real codec - VLC plays but WMP wont
By oglasifwd in forum Software PlayingReplies: 1Last Post: 5th May 2007, 20:20
