I've downloaded some music videos and want to put them onto a DVD-R.
The original WMV file per song is roughly 7mb but when i convert it to MPEG they're about 260-300mb each so i'm only going to get roughly 15 videos (approx 50 minutes viewing)onto 1 DVD-R.
Am i doing something wrong because at the start of using TMPGEnc it says
you can get upto 235 minutes on a DVD-R.
I didn't think a 5 minute mpeg video file would be so big.
Any help please.
I worked out that for a 5 minute clip @ 8000kbps, it will occupy 307.5MB of space. Because of this, I think that you may have left the bitrate on 8000kbps. Try dropping this to 4000kbps, and you'll fit twice as many on.
Bitrate (you probably know this) is the data allocated to describing the video in a set time. Dropping this will make your file smaller, at the cost of degraded quality.
https://www.videohelp.com/tmpgencdvd.htm - This covers WMV (same as AVI) --> DVD conversion.
https://www.videohelp.com/tmpgencexplained.htm - Here's a guide to every single TMPGEnc setting, and will explain the bitrate controls a lot better that I can just now.
Good luck,
Cobra -
4000kbps should be fine. I made a similar DVD myself at one point, and the bitrates I used I think were about 3500kbps. It came out at a very good standard, so I think you'll be OK. Experiment, and see how it goes.
Any more problems, just post up.
Cobra
wmv to flv converting?
By 2mmy in forum Video ConversionReplies: 1Last Post: 1st Aug 2008, 14:59 -
HD WMV converting to slow
By Illusionist in forum Video ConversionReplies: 15Last Post: 14th Jul 2008, 15:26 -
Converting wmv to ipod
By hunkofla in forum ffmpegX general discussionReplies: 1Last Post: 10th Jul 2008, 20:57 -
Converting DVD to WMV
By DELTAsnake in forum DVD RippingReplies: 1Last Post: 26th Mar 2008, 04:15 -
By Shibblet in forum DVD RippingReplies: 7Last Post: 5th Jan 2008, 06:19
