I have a leadtek winfast capture card on a P4 2.8 machine with a soundblaster audigy card. Im trying to set my resolution to 720X480 and I get an error. message. The error is 418 unsuported video format. Im capturing a VHS tape. How can I work around this. In the past I have used the original leadtek software with no proplems, except my finished dvd has audio synch problems about an hour and 10 minutes into it. The dvd was authored with X maker. The sound looks good in the raw captured file. Just looking to find an alternative capture source to fix the synch proplems. Thanks in advace.
What's up,
Yeah, I had that problem too. Is your capture card able to capture at that resolution? I tried to capture at 720x480, but my capture card was only able to capture at half that (356x240). Hope this helps! -
To use Dub with a BT card like the Leadtek you need to install one of the BT drivers to allow it to capture at full resolution. If you have Windows 98 you will not be able to install it. Some get better capture quality with them as well. I am not sure how they will effect FM tuner.
http://btwincap.sourceforge.net/
or
http://www.iulab.com/
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
