I have the DVD files on my computer (.vob files etc)
I use DVD Shrink to backup this DVD by adding the .vob files etc... it starts the encoding and etc and completes the burning.
But when I try to play the DVD-R on my DVD-Player (supports DVD-R) I get the following message on the display: INVALID TITLE
And at the end I get the message that there is no DVD in the player.
Whats wrong?
Results 1 to 23 of 23
You need to be a bit more descriptive. What's the process, to hard drive first or directly from DVD? Full disk or reauthor? What media? What DVD player?
Is this yuor first attempt or had other dvds worked? -
To Be, Or, Not To Be, That, Is The Gazorgan Plan
I have tried several times, but it has never worked.
I have a VIDEO_TS folder that contains a lot of .VOB .IFO .BUP
I want to burn this to a DVD-R so that I can play the movie on my standalone dvd-player.
I use DVD Shrink, open the folder (VIDEO_TS) and press the BACKUP button, and it starts to encode and burn it to the cd.
BUT, when i put the DVD-R in my standalone dvd-player I get the message: INVALID TITLE.****
Qbat
I havent tried it on another standalone dvd-player.. It doesnt work on my computer either.!Originally Posted by Gazorgan****
Qbat
try double-clicking on one of the 1G vob files from the titleset (in Win Explorer) that Shrink created and see if your PC dvd player can play it (your player i assume is already associated with the vob filetype) . if it does there is something wrong with the navigational structure of your dvdr; thus your PC player (and of course the stand-alone player) cannot play it from the very beginning.
BTW please explain this. if you literally did this you used Shrink incorrectly; Shrink has no way to directly deal with vob files.I use DVD Shrink to backup this DVD by adding the .vob files -
I tried to open the .VOB files with my DVD-Player with Power DVD and it worked. So it's something with DVD Shrink
Qbat
unclear what you did.I tried to open the .VOB files with my DVD-Player with Power DVD and it worked
Was this the ORIGINAL vob file(s) or the Shrunken one(s)? did you play it from the beginning in PowerDVD or as i suggested by double-click on a vob in Explorer?
okay, after re-reading an earlier post of yours i assume you can play back the original movie on your PC, not the Shrunken version. now please answer my second question. -
I have tried to open from the start and just a single .VOB file, works fine.!Originally Posted by noki****
Qbat
Qbat,
You tell us you have a VIDEO_TS folder.
Look if you have an AUDIO_TS folder too. If not, I believe that´s your problem. -
well, you got me
. i have found that if the filesize is less than 4.0G i cannot get it to play. BTW what version of Shrink are you using? if you already have not try v3.0 beta5. i've found it to be the most reliable of all of them, including the lastest 3.17. only thing it cannot do is accept output for TMPG DVD Author. good luck.
I use version 3.1.7.6 of DVD Shrink.
But, doesn't anyone know why I get INVALID TITLE on my standalone dvd-player? And when playing it on my computer it HANGS.!****
Qbat
Have you tried using different media? Tell us what media you are using, often times that alone is the biggest issue. I know it's hard to believe but very true.
I hate to be blunt, but it doesn't work because you are doing something wrong.Originally Posted by Qbat
We need to be able to eliminate certain areas as causes of your problems. It could be the media, the burning method, the transcoding method and/or the ripping method that is the cause of your problems.If in doubt, Google it. -
[quote="jimmalenko"]
I hate to be blunt
:P
Hey Qbat, how about filling in some details on your system?Pull! Bang! Darn! -
Qbat,
I suggest you find a guide and follow it, they work
jimmalenko gave you one above , did you try it.
or else find a guide here www.dvdshrink.info
many other guides around for DVDShrink
When I try to Backup DVD on Shrink...
By lblaker in forum DVD RippingReplies: 10Last Post: 24th Mar 2010, 21:08 -
Compressing .vob or .ifo files using DVD Shrink
By hostofsorrow in forum Authoring (DVD)Replies: 4Last Post: 21st Jan 2010, 23:19 -
Backup of a dvd movie using Ripit4me, Dvd Decrypter, and Dvd Shrink 3.2
By Gerald Sr. in forum DVD RippingReplies: 18Last Post: 16th Oct 2008, 16:55 -
Saw 4 does not backup using DVD Shrink
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 17th Apr 2008, 04:11 -
How to Shrink 7.7 GB VOB files to 4.7GB DVD on MAC?
By mc80 in forum MacReplies: 5Last Post: 30th Mar 2008, 10:41
