I'm using Pinnacle Studio MovieBox USB version 9 to capture my VHS tapes. I keep see on this foum and others that you should capture to .avi.
How can I do this in Pinnacle Studio MovieBox USB version 9? I have looked and I don't see an option to change from mpg to avi.
Carl
Pinnacle Studio MovieBox USB version 9 is an MPEG capture, it does not capture in AVI.
Is there a program that can use the Pinnacle Studio MovieBox USB version 9 hardware that will capture in AVI.
Carl -
I don't think there is. Capturing in avi is recommended if your capture device cant do a decent direct MPEG2 capture. If Pinnacle Studio MovieBox USB can do decent MPEG2 capturing why bother capturing in AVI - that will beat the purpose of MPEG2 hardware encoding (time saving encoding)
If you really want to capture in .avi then get the ADVC 100 or the
Studio MovieBox DV version9 instead.
Cheers.
Help with Virtualdub and Pinnacle MovieBox 710-USB
By cgarai in forum Capturing and VCRReplies: 3Last Post: 7th Apr 2012, 00:14 -
Is There Such A Thing??? re: Pinnacle Studio 500 USB
By drtalk in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2010, 19:21 -
Pinnacle Studio MovieBox Ultimate vs. DVD-recorder
By fabitos in forum Newbie / General discussionsReplies: 6Last Post: 24th Nov 2009, 07:04 -
Pinnacle Studio version 12 guide/tutorial
By avz10 in forum EditingReplies: 2Last Post: 13th Oct 2009, 17:04 -
Limited capture success with Pinnacle MovieBox Plus 510-USB device
By ccooper in forum Capturing and VCRReplies: 4Last Post: 17th Jul 2009, 11:52
