I'm sure you guys get this problem alot, but I'm still a n00bHow would I go about putting an AVI video on a DVD-R that will play on a regular DVD player? I've tried many online guides, but something always goes wrong for me.
From what I've learned im suppose to conver the AVI to a DVD compatible MPEG2, then author it and put the video and audio files in the TSS file.
Any help would be appreciated. Thanks guys![]()
Results 1 to 16 of 16
You need to Convert, Then Author and Burn. There are sections for guides on these areas over ther <=========.
Read some guides, pick one that appears to meet your requirements and try to follow it. When you have problems feel frre to come back and ask specific detailed questions regarding said problem.
No one is going to hold your hand and walk you step by step through the processes you need to follow. Also there are many ways of doing what you want not all of which will suit you.
Help us to help you. -
It's cool, don't worry about it this is not the most straightforward process you could do, but I will try to help. you will need the following programs
Virtualdub
dvd2svcd
Dvd2svcd requires CCE or tmpgenc and sonic
any author program you would like ( I use tmpgenc dvd author and dvdlab)
*****This is the Step people always forget and it is very important, if you don't do this you may have a bad AVI file and therefore Bad DVD******
Open your avi file in Virtualdub
Under the video tab select Direct stream copy
Under the Audio tab Selct Full Processing Mode and the following
Compression > None PCM something or other (it's the first choice)
Conversion > 48000, 16 bit, High Quality
Under File Tab Select "Save As AVI"
this will take a couple minutes to complete
Exit Virtualdub and reopen
Load the new AVI in Virtualdub and check to make sure the audio syncs up the way it's supposed to, if so close virtualdub, if not go under the audio tab and select interleaving and change the delay until the audio does sync up. Then go through the process from above and "Save As AVI"
Make sure you chose Direct Stream Copy under the video tab or you will have a huge file, and it will take a long time.
This should ensure that you have a good AVI File to work with in dvd2svcd
Now open DVD2SVCD this program is pretty straightforword let me know if you need help with this, but you essentially just need to go through the tabs and select the options you want.I'll turn my back on myself, if it's my only way out. -
look to the left click tools then click codecs and find divx3.........It says the video codec is not installed
Bah, i got it to the point where its ready to burn but i always get a "drive not ready" error. The drive works, its a combo drive and ive burned a few cds with it. Thanks for all your help anyways guys
Bah, i figured it out, HP DVD writer will not record on DVD-r only DVD+r.
Keep going, you're getting closer!
"Art is making something out of nothing and selling it." - Frank Zappa -
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 10:32 -
Help putting AVI files onto a DVD!?
By rightsidebrain in forum MacReplies: 10Last Post: 24th Mar 2009, 09:40 -
Is This A Common Problem? DVDr to AVI
By innovyse in forum DVD RippingReplies: 1Last Post: 21st Jan 2008, 06:09 -
Putting two AVI files on the same DVD
By Mr Sorrow in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 27th Oct 2007, 08:57 -
question about putting subtitles into avi
By pike8 in forum SubtitleReplies: 2Last Post: 15th Jun 2007, 12:42
