I have had a sony DRU-500A since release
But im having a bit of trouble
I can only burn at 1x to get a completley error free disk (Using DVD Info Pro)
every time i go to 2x and 4x i get losts of read erors on the last part of the disk. I have only once burnt a completley error free disk on 4x and dont want to waste lots of disks on 4x with read errors.
Here is my computer setup
IDE Cable 1
Master - 60GB HDD = 2 Partitions
Slave - 20GB HDD = 1 Partition
IDE Cable 2
Master - Sony DRU-500A Firmware 2.0H
Slave - DVD Rom - Liteon
Win XP Pro
256 DDR Ram
64mb Video
Burning With DVD Decrypter, Nero and Record Now Max
Is there a better way to have them setup on the ide cables, or have error free burns
any help would be great
neo
You've left out the most important part of the equation. What kind of media are you using. Bad media will typically burn "well" at 1x and if you crank up the burn speed, that's when you begin to experience problems. You also did not mention whether the resulting DVDs play well on the standalone player, no matter what DVD info reports.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
sorry about that
Im using Princo 4x Disks
and they will play but the last bits will go all bocky and squary. -
Simple. Don't use Princos, they aren't for your Sony & they also tend to delete data after a year. Get the right media. How about some Accus or BeAlls? Don't change your firmware without keeping the old firmware somewhere cause Sony doesn't keep it for download.
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 11:52 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21 -
where to get original Sony DRu-820a DVD Firmware
By scustalow in forum DVD & Blu-ray WritersReplies: 1Last Post: 15th Jun 2007, 11:00 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 08:41
