can anyone give me any ideas how i can convert this ntsc avi to pal!! maybe i dont have to !! i am not so sure . My standalone alone dvd will play ntsc 23fps !! on my pal tv.
If your standalone plays back NTSC on your PAL TV (as mines does) then you need not convert it. Follow the guides for converting it to whatever the target format you are after (eg SVCD or DVD) and it'll do fine.
Cobra -
cobra , thx for the quick answer!
i thought maybe that it would play on my standalone dvd - but i did not want to go through hours of conversion and adding subtitles to find that it did not play!
ill try it -
Why don't you just make a small section of your video, perhaps the first five minutes and then burn it to a DVD+/-RW to see if it works? That's what I do, and it's saved me a lot of coasters since I'm a fidget and I like to mess about and find limitations.
Cobra -
This guide works for me
ntsc avi to pal dvd --->
https://www.videohelp.com/forum/viewtopic.php?t=209166 -
Well then convert the NTSC 29.970fps AVI to an NTSC VCD but just do like 5 minutes worth then burn on a CD-RW or even just a regular CD-R since they are rather cheap.Originally Posted by anglia
If it works then you know that you can avoid the NTSC to PAL conversion which can be rather tricky.
720p conversion of PAL 25fps to NTSC 59.94fps using Handbrake?
By texas1 in forum Video ConversionReplies: 7Last Post: 29th Jan 2012, 12:06 -
is it possible to ivtc a 29fps ntsc source to 25fps xvid with gnot?
By iamtehsux in forum Newbie / General discussionsReplies: 65Last Post: 28th Dec 2010, 09:22 -
converting PAL (25fps) to NTSC(23.97fps) with audio
By drew24 in forum MacReplies: 6Last Post: 21st Dec 2009, 10:45 -
Changing AVI from 29fps to 25fps
By Ric76 in forum Video ConversionReplies: 11Last Post: 22nd Jul 2009, 15:12 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 23:31
