I bought the above player last weekend but hardly used it this week as I was waiting for some dvd ram discs to come I ordered on the net. The discs are Datasafe 9.4g in caddies. Yesterday I recorded 1 hour in LP mode, 2 episodes of the simpsons. Started watching the recording last night and halfway through the first episode the picture started blocking up badly, like a poor downloaded movie clip. I haven't investigated this further yet, could be a dirty disc ( shouldn't be as disc in caddy ), could be poor quality media or compatibility. Maybe even the E55!.
What do you think?
Kevlar
I had the same thing happen to me with an E50 about two months ago.
It was the second day of it being on the job, and I was recording some stuff on Memorex (yuck) disks. I didn't know that Memorex sucked at that time...
Anyway, I was trying to bring over a show I'd taped off of TV when the reception was bad, and it seemed to work alright on the RAM disk I had.
However, I noticed that the thing went all blocky on me when I tried a conventional DVD-r.
I have heard that if a signal is really noisy, then it will sometimes break up on recording. However, I don't understand why the RAM would do the job but the -R wouldn't. On top of that, I thought it might be the media, since the unit went into a recover shortly thereafter.
However, I think it was actually the E50. I tried several disks after that and they all blew up the same, and then the unit wouldn't even record off of TV!
You and I might both have got bad units, I'm afraid. I took mine back, and told the salesman what happened. He said he'd never heard of such a thing, but he did give me a replacement.
Don't spend time screwing around. Go get a replacement for your unit and see if the same thing happens again.
This is one of the reasons I still TAPE everything I want off TV. I've never seen a tape go all blocky. Then, when I want something for good, I can transfer it to disk.Mechworker -
Thanks for the reply m8. I've just erased the recording and tried recording/playing back the recording at the same time in XP mode as this will cover the whole disc in 1 hour, and guess what? after about 5 minutes it went tits up all blocking etc. I pulled the caddy out, slid the cover accross and slowly turning the disc I found a blob of fluff on the disc, like a little bit of felt. I removed this and am now trying again, hopefully will be ok. The question remains though how did it get on a brand new disc in a caddy? I haven't seen a bit of fluff/dirt that big on a bare disc!
One observation though, have you seen the surface of a ram disc? wow....I can see why they cost at least 10 times more than a dvd-r.
Kevlar -
On my unit, I was using standard -R disks, no caddy at all.
I've never even seen a disk in a caddy, although there's a line drawing of one in the E50's manual.
Weird about the fluff. I didn't have that problem, mine just crapped out.
Best of luck, man, and let me know how it goes!Mechworker -
My panasonic came with a panasonic dvdram which works perfectly. I use Accu dvd-rs with 100% success.
Always test with the manf's media.
dvdram has a rewrite rate of 100,000 times.... -
I written a lot of movies to dvd-r on my pc, the best discs being anything with the dark purple Ritek dye. I there a preferred brand when it comes to Ram discs?
Kevlar -
Morning,
hmm, stranger and stranger. If you take a look at my thread here https://www.videohelp.com/forum/viewtopic.php?t=207885&highlight= you'll see I had almost exactly the same problem with an E50 following the return of which I'm currently waiting to take delivery of a new E55 unit.
Anyone else had this sort of problem, could it be a defect in the lens / optics unit or a problem that has occured due to the use of datasafe DVD RAM disks ?
Also are you both in the UK, the US or elsewhere ? I'm in the UK but wonder could it be a batch or a predictable fault on the E50 and early E55 units ?
Hmmmm...
Cheers
Edz -
I'm in Canada. (I'm a colonial to you guys I guess, eh?)
This is a bit worrisome, although my current E50 is doing well. I've put almost 300 hours of recording on it now, so far so good.
I've also been having a problem with my RV31 unit that I use for playback. A few times now it has been suffering picture dropout. I'll be watching something, and it will just go black.
Sometimes, it gets really dark and looks Macrovision-y, but that's not the problem because it does it on commercially pressed disks too!
Any problems like that out there?Mechworker
picture control on Panasonic dmr e55
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Jan 2012, 17:41 -
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 10:42 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
black bars on sides of screen, Panasonic s97 to Panasonic e55
By southland66 in forum DVD & Blu-ray RecordersReplies: 14Last Post: 10th Sep 2008, 18:15 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33
