Hi guys,
I saw in the DVD player compatability links that the ROTEL RDV985 is compatible with DVD+R media. I have backed up DVD to DVD+R media and they don't read in my ROTEL. I have tried them on a PC and on a Toshiba and they worked fine.
My recorder is an LG and the model is GSA-4081B.
I am using Verbatim DVD+R media.
I read something about bitstream that may be the problem but I didn't quite understand everything and the software bitstream doesn't work on my DVD recorder.
I have the following questions:
-Should I use another brand of DVD media?
-How does bitstream work and is it possible to use on LG GSA-4081B?
-Anyone else with a ROTEL RDV985 that was able to read DVD+R, how did you do it?
Sorry for such a long post
Thanks and Best Regards
You need to find a media that works with it. Try -R as well. Usually that's more widespread compatible then +R because it's an older format. Try different brands as well. Not all disks are made the same.
Supposedly the ROTEL RDV985 is only compatible with DVD+R media. Also somebody mentioned this is the compatability lists. I will try with other brands - any suggestions as to which brand works best for you? I saw the post on What's the best brand? and became even more confused.
Thanks for your reply
Best Regards -
I would still try a -R disc. NOT that they are hugely more compatible than +R's....it's just the circumstances. If +'s aren't working there is only one other option....-'s.
+R's from a DVD Recorder are VERY compatible.
-R's from a computer burner are VERY compatible.
I have an LG 4040B and a Philips DVDR985 Recorder. I use mainly -R's in my burner and obviously +R's in my Philips...I have never had anyone who has bought one of my DVD's e-mail me saying it will not work in their DVD player.....and that is for both the Philips created discs AND the computer burned discs.
Backed up VHS tapes on one DVD, need to create menu DVD
By perceptionist in forum Newbie / General discussionsReplies: 6Last Post: 11th Mar 2011, 17:57 -
Can't rip already backed up DVD, tried imgbrn, DVD shrink, DVD decrypter...
By perceptionist in forum DVD RippingReplies: 10Last Post: 26th Sep 2010, 23:52 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
Panasonic Blu-Ray player won't show Backed Up DVD or.....
By Scooter_NJ in forum DVD & Blu-ray PlayersReplies: 18Last Post: 3rd Sep 2008, 14:37 -
Rotel 7.1 MPEG Multichannel Decoder....any others?
By Disco Makberto in forum AudioReplies: 9Last Post: 30th Nov 2007, 05:23
