Hi : I got a panasonic e55 the other day. Besides ordering cable tv service, and finding a beta vcr (probably off of ebay). I'd like to get a dvd-ram drive, so I can edit the beta home movie tapes I plan to use the e55 to transfer to disc.
The strange part of this (ordeal) is in deciding which dvd-ram drive to buy. I really have not seen much to choose from. Maybe my search skills stink. I already have an NEC-2500a +/- 8x burner, but it does not read ram, just rom. So far, about the only drive I have seen recommended, is the Toshiba SD-M1712 at newegg for 29.00. Any other choices I should consider ? - Thanks
Oh yeah, I almost forgot - Can I use the dvd-r disks to edit ? I know I will not be able to reuse them
__________________
LG makes a reader (at NE), but for just a reader I've always heard good things about the Toshiba. I guess you're not really asking for this, but LG also makes a burner that has been rated excellant and also does DVD RAM both reading and writing.
get LG GSA-4082B or any earlier LG model (GSA series). They all read/write to +R/-R/+RW/-RW/-RAM, and the latest one (4082) does both +/- at 8x and DVD-RAM at 3x (supposedly, because I never got full 3x on any of them).
Once I had earlier model of panny too, thats why i thought I'd try and bought back then my first LG writer (GMA-4020). Since then I dont buy any other dvd writers but LG
Theyre really that good
Easy edit DVD video cutting out unwanted stuff without recompressing
By deadp0et in forum EditingReplies: 6Last Post: 7th Feb 2011, 08:49 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 14:09 -
DVD Ram Drive
By gemma-the-husky in forum DVD RippingReplies: 5Last Post: 26th May 2008, 19:49 -
Recovering stuff from my formatted USB Drive
By SIRCOOKS in forum ComputerReplies: 25Last Post: 17th Feb 2008, 21:36 -
DVD-RAM corrupted in PC drive?
By AlanL in forum MediaReplies: 6Last Post: 11th May 2007, 12:08
