Hello all and thanks for reading
Hope you can advise me on my problem
I have been trying to use dvdshrink it worked a couple off times fine but the other day it froze while doing the analysis it actually froze the whole pc and i had to reboot since then my computer takes a long time to start.
and i have tried a lot of my orig dvd just as a test and 50% will freeze during the analsis but not allways at the same spot.
I am using winxp
p-4 3.0
512 ram
nec1300a dvd
dvdshrink 3.1.4
Results 1 to 11 of 11
I'll second that. Stable preferred versions (for me) are 3.1.7, 3.0 beta, and 2.3 in that order. If you fail to get at least one to work, your computer's got bad problems. Do a little housekeeping if you've not done so already. Good luck.
Pull! Bang! Darn! -
Thanks guys
overlooking the obvious again
I'll give it a go now and let you know how it goes
Thanks -
try ripping with dvd decrypter first, and use dvdshrink to analyse from the files on the hard drive
Downloaded and installed dvd decrypter
run it through a few times with different setting and all seens to go fine
When i use dvdshrink and try to read the files on th HD that were created by dvd decrypter i get a message saying.
carnt find video_ts_ifo
does someone know what i'm doing wrong
thanks... -
what guide are you following
follow a guide from here
www.dvdshrink.info -
Thanks for all the replys
I got pissed off and decieded to do a restore tried again and they worked just fine it may have bee the last windows updates i installed.
Yes i'm still using the orig firmware 1.06
is it hard to upgrade what is the benifitif all is working fine
Thanks again guys
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
analysis: more than 16 cores pointless
By deadrats in forum ComputerReplies: 49Last Post: 18th Dec 2008, 08:53 -
Software for analysis CD/DVD
By grzegorz in forum Newbie / General discussionsReplies: 3Last Post: 21st Apr 2008, 20:14 -
"DVDshrink - Vista where is Application Data Analysis files located?
By mn072065 in forum DVD RippingReplies: 2Last Post: 24th Feb 2008, 17:43 -
AutoGK Analysis, how good is it?
By hotwings in forum DVD RippingReplies: 4Last Post: 30th Jun 2007, 13:34
