Hi guys,
I need help copying a dvd, it has some copy protection i cant figure out,
Ive tried using dvdshrink and dvd decrypter but it keeps coming up with errors that the dvd is copy protected,
the dvd is a backup not an original,
please help,
regards,
Rick
What kind of error exactly are you getting?
Perhaps you could do a screen capture and post it here so we can see.
Also try ripping with a DVD burner vs a DVD-ROM
Use the DVD burner that made the DVD in question if that is possible.
Was the backup done with DVD X copy?
You should be able to just drag and drop the AUDIO_TS and VIDEO_TS folders and not need to "rip" them...if it is a backup.
Copy right protection on Glee?
By chiburu in forum Newbie / General discussionsReplies: 14Last Post: 24th Sep 2010, 10:47 -
Copy Protection
By Big Jake in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2010, 14:31 -
Rendition - New Copy Protection?
By funnel71 in forum DVD RippingReplies: 27Last Post: 27th Feb 2008, 05:37 -
CD copy protection
By KingSeti in forum Off topicReplies: 14Last Post: 26th Feb 2008, 12:01 -
Comcast and copy protection
By BobT in forum Capturing and VCRReplies: 9Last Post: 5th Sep 2007, 21:06
