I'm trying to update Encore, using the 3.5MB update downloaded from Adobe. But it will not run, always bringing up the error "The updater cannot find Adobe Encore DVD 1.0 in ..... Please attempt to locate Adobe Encore DVD 1.0 again or cancel the update and install Adobe Encore DVD 1.0 from the original disks or CD."
Has anyone else had this problem or does anyone know the fix?
Common problem for non legit copies of encore. If you copy is legit try uninstalling encore, turn off windows xp system restore, reinstall encore and then install the patch before your restart your computer.
Encore help
By Entengdigital in forum Authoring (DVD)Replies: 8Last Post: 5th Sep 2011, 22:08 -
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 16:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 13:02 -
Adobe Encore
By mobie29 in forum Authoring (Blu-ray)Replies: 33Last Post: 6th Jan 2011, 02:09 -
Help in Encore
By sk8_aholic in forum Authoring (DVD)Replies: 0Last Post: 13th Nov 2008, 01:33
