Hi everyone !
I got a directory called VIDEO_TS contains a Ripped film of DVD , I wanna burn it into a DVD-R but before that I want to remove some bad Frames from the Film before I burn it or make it an image , is there any way to do that withought converting it to avi ? Any Programm for that ?
As Example , The Film contains some bad things in it and my children wanna watch this Film , but I don't like to show them this bad scenes , this is why I want to remove them from the movie ...
I hope you can help me with that .
Thanks for any help !
Theoretically one could use DVDShrink. Re-author the film (you'd lose the menus unfortunately) and use the start and end markers for the portions you want to keep. There is a guide available
http://www.dvdshrink.info/reauthor_intermediate.php -
Thx. for your answering me JMO ...
But will TMPGEnc DVD do the trick ? I hope that because I use TMPGEnc plus to edit my AVI files and converting them to VCDs so I am happy with that client ... But Does the TMPGEnc DVD make what I am looking for ?
Thanks ! -
You could use TMPGEnc DVD Author to edit out sections you don't want your children to watch. But again, you'd be re-authoring, so you would lose any menus that you have. Of course you can use TDA to make your own menus.
they should sell dvd's with paper bags
Can't remove DRM on a film...
By takearushfan in forum Video ConversionReplies: 13Last Post: 3rd May 2011, 08:16 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 16:14 -
Remove Duplicate Frames
By robindean in forum Video ConversionReplies: 26Last Post: 11th Mar 2010, 15:30 -
How do I introduce a picture in the frames of a film?
By Yogy in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2010, 22:44 -
How to remove a single or more frames from a DVD
By justmehere in forum Authoring (DVD)Replies: 2Last Post: 22nd Apr 2008, 12:06
