For all those who use after effects, I have a quick question. I downloaded the trial and before I buy it, I wanted to know if you can date/time stamp in it. I read here it can be done but the search has yielded zilch. Is it possible or am I wasting my time? I'm pulling in info from my camcorder through firewire. I know dv time stamp will do it, but before I purchase that, I'm a little concerned with the text quality.
Any after effects junkies that might know? Thanks.
what DV time stamp does , AE can not do
I'm not sure. I have tried alot here. I recently did the one where you drag it to create a css file or something but the blue box never goes away. I really think the dv time stamp will work. but I just wasn't happy with the pixel quality but if I have to use it, then I will. I heard after effects would so I downloaded it to try it for 30 days. I have adobe premier pro, ulead workshop 2.0, and I still can't seem to find anything.
Thanks for all your help. -
Take a look at Premiere Pro. You should be able to create a text layer to overlay over your video (text mask). Then all you have to do is type the date/time/etc. right on top of your video & then resize it & place it in the corner of your project window.Originally Posted by jay24k
If you are looking for a cheap & easy program to do this with, Vegas has an LE version which supports up to 3 or 4 video layers. Just insert a new text layer on top of your video. The rest is pretty easy.
Boda
Adobe After Effects, how do you view all layers at once??
By Devilsadvocate in forum EditingReplies: 5Last Post: 2nd Mar 2012, 12:58 -
Adobe After Effects Questions
By HoosierGuy in forum EditingReplies: 25Last Post: 2nd May 2011, 22:12 -
Replacement PC for Adobe After Effects CS5
By lowellriggsiam in forum ComputerReplies: 0Last Post: 25th Jan 2011, 11:14 -
Adobe After Effects issue
By Coroni in forum EditingReplies: 3Last Post: 22nd Oct 2010, 21:56 -
Twixtor for Adobe After Effects CS4
By Tahlos in forum EditingReplies: 4Last Post: 5th Oct 2010, 21:57
