i got this old card from a friend. I have been trying to install this on my computer and capture tv w/o success.
First i tried installing in win xp, could find any working driver. Then i found the univerisal tweaked wdm drivers from iulab.com. Driver was install successfully. However, i can't find any software to capture to working successfully.
then, i tried installing in win98 (Original not SE). using wdm driver and visual reality, i got it to capture. However, it was capturing at 2gb / 15 minutes. I tried to use virtual dub and real producer 8 but they could find the capture device. I spoke with a friend, he think it's because i install the wdm drivers. virtual dub and real prodcuer 8 look for vfw driver. Now i really confused.
Somebody please help. I like to get this thing to work. I very new in this capture stuff. Especially if you got this card and it work, please share your knowledge in detail, i will be forever grateful..
thanks.
all of your assumptions thus far are correct. i doubt there are win xp drivers for your card and the majority of 3rd party capture software utilizes the video for windows architecture(vfw). try windrivers.com if the company is defunct
<font size=-1>[ This Message was edited by: stanwebber on 2001-11-06 13:34:00 ]</font>
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
The Best USB Tv Tuner / Card around ?
By rock_king_my in forum Capturing and VCRReplies: 1Last Post: 16th Dec 2008, 22:44 -
tv tuner card help!
By johanc in forum Video Streaming DownloadingReplies: 2Last Post: 7th Dec 2008, 07:02 -
I use these programs for my tv tuner card
By Milardo in forum Capturing and VCRReplies: 5Last Post: 17th Jun 2008, 05:28 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51
