I am trying to back-up finalized discs I burned on my Panasonic E80 using DVD Decrypter. I have ran into the following problem. In ISO Read mode, the process starts to fail somewhere after 90%. If I abort the process at that point and save the "incomplete" ISO, I can burn it normally into a DVD using the ISO Write mode in Decrypter or just the burning engine in Nero. My impression is that the ISO reading process chokes as soon as the end of the data section in the original disc is reached, even though it's been properly finalized (writing of "emptier" discs fails earlier than that of "fuller" discs). Why is this happening? Do I need to change my decrypter settings? I have tried it with all kinds of media and the same thing always happens. Any help will be appreciated.
dvd decrypter's ISO Write function is known to have problems, esp. when burnproof is used. this has been the case from v3.16 on. i would just burn the image with Nero. also you have some contradicting statements in your post. might want to edit it.
In ISO Write mode, the writing process starts to fail somewhere after 90%...I can burn it normally into a DVD using the ISO Write mode in Decrypter -
LOL, you're right. I contradicted myself. I meant to say that the failure is on ISO Read mode. I edited it. I'll try to do it disabling the Buntproof and see what happens.
question regarding DVD Fab Decrypter
By Bamahusker in forum DVD RippingReplies: 2Last Post: 3rd Mar 2010, 17:02 -
DVD Decrypter Question
By jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 28th Jan 2010, 04:56 -
dvd decrypter/dgindex question...
By alcOre in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2009, 09:35 -
New to Board DVD Fab HD Decrypter 4 Question
By marine89052 in forum Authoring (DVD)Replies: 3Last Post: 27th Mar 2008, 23:33 -
DVD Decrypter Region Question
By nickolasj80 in forum DVD RippingReplies: 2Last Post: 21st Jun 2007, 19:26
