Captured mpeg2 files with leadtek winfast expert play fine with neroshowtime or ati file player but when I author with tmpgenc the audio goes out of sync after 10 minutes of playback and gets worse as it progresses. Is this a known issue and is there a fix for this? I'm using the latest drivers and winfast pvr from leadtek's site. Thanks for any input
Results 1 to 10 of 10
Originally Posted by jamawass
What is your source material? If it's tape, I suspect that's where the root of the problem is. Tape captures are notorious for causing sync issues. Also, software can cause dropped frames as can IRQ sharing and PC speed issues.
Maybe if you provide more information someone can offer a suggestion. -
System is Athlon 64 3200, 512 Mb mushkin ram. SATA 120 8 mb cache hard drive, win xp pro, sp 1, phillips rythmic edge sound card, pioneer dvr a06. -
Your system specs are more than capable of doing the job - nice rig actually. Could I ask which of the Leadtek cards you're using?
Also having one of the Leadtek cards myself, I know one can capture - DVD NTSC or MPEG2 (Normal, Good or Optimal quality). I'm sure you know what I'm talking about. Which one of these do you use?
wecc -
Originally Posted by wecc
Im have some of the same issues. My capture audio synch looks good until I author it. Then about an hour in to the dvd the audio looses synch. Im running XP pro P4 2.8 on ECS Mother board leadtek winfast tv 2000 card with sound blaster audigy have a seperate HD for capture. DVD was authored in DVD x Maker. Thanks in advance.
Try loading the MPEG file into VirtualDubMod and check the frame rate to see if the video and audio match ... both should be 29.970fps
If not then maybe you can demultiplex and adjust the audio to match using a WAV editor or perhaps even BeSweet.
Then multiplex and double check again in VirtualDubMod.
I've noticed this does not seem to be a consistent problem the only time the synch issue occured was when the file was captured in the background when my wife fast user switched to her desktop. My theory is that leadtek compensates dropped frames by " padding" the file. When the file itself is played back there are no problems but authoring results in the padding being removed from the file with resulting sync problems. Earlier versions of ATI MMC used to have this problem.
A file I captured yesterday authored without any sync issues after authoring. Winfast expert is a resource hog even with my system, tv viewing is about 20% cpu usage(5%with ati) and mpeg capture is close to 50% (25% with ati aiw). If you have a less powerful system leadtek may be " padding" your file to compensate for dropped frame rates. -
Well damn thank you for wasting our time ... I mean really now!
Video Capture 101
Do NOT do anything else when you are capturing.
Kick your wife upside the head for me!
Originally Posted by FulciLivesAthlon 64 3200+
MSI K8T Neo-FISR, Mushkin PC 3200 512 Mb Ram
Leadtek winfast expert, Radeon 9600XT, Pioneer DVR A06, Win XP Pro SP 1, Via hyperion 4.49
fast forwarding authored DVD causes sync problem
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 00:10 -
WinFast PVR captures audio in PCM only
By jaceko in forum Capturing and VCRReplies: 4Last Post: 13th Sep 2009, 16:24 -
DVD player issues, copy is ok but authored fails
By cr4sh in forum Authoring (DVD)Replies: 4Last Post: 19th Sep 2008, 17:24 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 07:13 -
Lip sync on video captures using VIVO card
By Confused Chimp in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2007, 18:36
