I was given finished m2v files by the client(who shall remain nameless for fear of embarrasment). They somehow got the feilds swapped so it's looking pretty bad.
Is there anyway to fix this? I don't need to convert these and I don't want to degrade the signal in any way. I just need another m2v file with proper blending.
true to the tri
Thanks I'm messing with it right now trying to fix them. So far it doesn't seem to be correcting the problem but I'm just messing with the setting til I get it.
true to the tri -
It may be too embedded. AT some point, a file can be beyond RESTREAM, but it normally fixes it. Swap the field order tab (check ot uncheck) and try a sample clip both ways.
The only thing that can go wrong is mixed 24/30 fps -
Originally Posted by FOO
I had to re-encode video once or twice from source because the field order was wrong twice, and apparently the error became embedded in the video.Want my help? Ask here! (not via PM!)
.dv creating files everywhere when converting to DVDMPEG2
By RL in forum ffmpegX general discussionReplies: 0Last Post: 30th Jan 2011, 18:30 -
Changing VOB file audio track order
By mmdmmd in forum EditingReplies: 1Last Post: 4th Oct 2009, 15:12 -
ImgBurn and File Order
By ctdvd in forum MediaReplies: 4Last Post: 28th Sep 2008, 13:32 -
Imgburn and file order
By marioval in forum Newbie / General discussionsReplies: 6Last Post: 6th Aug 2008, 00:13 -
Changing Filed Order in IFO-file
By Dima P. in forum Authoring (DVD)Replies: 3Last Post: 22nd Jan 2008, 13:37
