I have an avi file and when I play it, the sound is not synchronised with the image. Is there a tool to make that right ?
Try Virtualdub. Go to Audio>Interleaving and manually adjust the audio skew value until it syncs up. When you save as avi, make sure you have direct stream copy selected in the video menu. You can preview before saving by clicking on the second play button that has an "o"(output).
try searching the internet for your question, i had the problem before a quick search and you'll get tons a places to go. also search the guides here for your problem
here's one guide i found here: https://www.videohelp.com/forum/userguides/140540.php
or try a different program, thats solved my probem. by trying to fix the problem yourself i found that it deals with a lot of cutting either video or sound out of your avi fix, but shouldnt be noticeable, unless the audio and sound is out of sync really bad or something
hope that helps
alright
Quick way to merge a Cover picture(preview picture) in a video-file
By arty1 in forum Video ConversionReplies: 0Last Post: 6th Mar 2012, 01:06 -
Sony Vegas - Picture-in-picture video creation
By jeanpave in forum EditingReplies: 5Last Post: 13th Dec 2011, 23:01 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 04:52 -
DTS Express PiP (Picture in Picture) / BD Rebuilder question.
By rippn in forum Blu-ray RippingReplies: 4Last Post: 23rd Nov 2009, 16:41 -
Avisynth Picture in Picture Script Slows Down Video and Lacks Sound
By OpNash in forum EditingReplies: 2Last Post: 26th Nov 2008, 20:00
