I am capturing using MJpeg codec and would like advice on what sound codec to use . Pcm seems to be the prefered one but is there one that will give the similar resultes but a smaller overall file size.
Jason
PCM isn't so much a codec as it is simply the raw data. It is completely uncompressed, and is also known as WAV or CD Audio.
If you're capturing, I wouldn't suggest trying to compress the audio into a format such as MP3 at the same time. It may cause your machine to drop frames due to a lack of CPU power, so you'd swap a little space on your hard drive for a poor or flawed capture.
Also, I found that when using Morgan MJPEG Codec, the quality of 90 was the best balance between space and quality. Just a tip.
Cobra
Convert to MJpeg
By gmellow in forum Video ConversionReplies: 18Last Post: 29th Jan 2015, 05:21 -
converting to mjpeg
By GodsOtherHand in forum Video ConversionReplies: 1Last Post: 7th Apr 2011, 15:03 -
MJPEG export
By vizion in forum ffmpegX general discussionReplies: 2Last Post: 9th Feb 2011, 12:52 -
Help in created a pesdo codac in wmv and others
By Caprice0495 in forum ProgrammingReplies: 0Last Post: 8th May 2008, 18:17 -
MJPEG Testing
By adambklyn in forum Newbie / General discussionsReplies: 1Last Post: 9th Oct 2007, 01:04
