The ac3 sound is too soft, is there a way to increase the vol before authoring?Can besweet do it?
Rip the audio out, use GoldWave or something to increase the amplitude (beware of clipping) then remux and author. If you're not too concerned about the dynamic ranging of the audio (which is why AC3 is so soft sounding) then normalise it out.
Cobra -
hmmm -- not really the way you should do it ..
you should set dialog normalization and dynamic range compression correctly .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Soft Anti-copie
By youneslalami in forum ProgrammingReplies: 8Last Post: 30th Dec 2011, 22:46 -
what is the difference between soft, neutral, and sharp?
By noobiestudent in forum Newbie / General discussionsReplies: 8Last Post: 8th Jun 2011, 17:22 -
what edit soft for old pc
By runnernorth in forum EditingReplies: 12Last Post: 1st Mar 2010, 03:33 -
Soft Sub to Hard Sub
By taylordotcom in forum SubtitleReplies: 1Last Post: 20th Feb 2008, 01:35
