I have an avi file with framerate 23.97, when I used TMPG to covert to a dvd format, should I used the same framerate or the default rate used by TMPG i.e. 29.97? Is there any difference? Will the final picture be slightly jerky? Thanks
You mean I should unlock it , change to 23.97? Why does TMPG default to 29.97? What does the pulldown do? The default is non-interlaced.Sorry for all this question. Pl help. I experience some jerkiness but not in all avi.
set Encode mode - 3:2 pulldown on playback
set "do not framerate conversion"
set Framerate "23.976 internally 29.976 -
I really don't know much about all this, since I'm in PAL land, but hopefully a more knowledgeable person can correct my mistakes:
What TMPGEnc defaults to is determined by what template you have loaded. I believe the pulldown tells the player to convert to 29.97 on the fly (while playing) so that everything stays in sync.If in doubt, Google it. -
29.97 is dvd compliant framerate, but you can use 23.97 with 3:2 pulldown. It will change the framerate to 23.97 internally (29.97)
you don't need to check "do not framerate convert" -
"do not framerate conversion" is just insurance in case
it's not exactly on
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
