I have a DVD-RW and a DVD+RW disc which I use at home on a NEC 1300A burner. I have no problems with writing, reading or erasing in Nero 6 these discs on my own computer running Win98SE. But as soon as I bring a disc home to a friends HP writer running XP it will not even access the disc. The disc cannot be read and the computer just freezes, but the disc works fine when I get home.
Can there be a reason to suspect that the disc is locked to my computer and/or my operating system? Is there any way that I can reformat the discs at home before taking it home to my friend? Do I need to install XP? Any other suggestions?
Kal
Not all DVD burners read (or write, for that matter) DVD-RW/+RW.
It may simply be the type of burner your pal has and no, it isn't locked to just your PC.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Sorry, my mistake. In this case it was the DVD+RW and yes, his burner is a + burner and he himself has several DVD+RW discs, even the same brand as I have.Originally Posted by Will HayKal
If you are writing data to the disc, your friend would need the same packet writing software installed on his/her system in order to read the data.
This does not apply to discs written in DVD Video format, only UDF format. -
OK I accept that. In this case we are both using Nero 6 and the disc was written in UDF/ISO format.Originally Posted by tekkiemanKal
Need to wipe drive
By neworldman in forum ComputerReplies: 18Last Post: 19th Nov 2011, 13:24 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 18:42 -
Virtualdub....An out-of-bounds memory access (access violation) occurred...
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 8th May 2010, 01:40 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 09:34 -
Sony´s DCRDVD403 won´t access its own disc
By wvpneto in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Jun 2007, 21:48
