I have done it the other way round (VCD header on an SVCD) but never heard of this. Are you sure this is what you are doing? If so why do this?Originally Posted by indianmassive
Now that makes more senseOriginally Posted by indianmassive
The reason for doing VCD header on an SVCD is because your DVD player does not support SVCD. As to why your DVD player does not 'officially' support SVCD, it could simply be that the manufacturer did not wish to pay the extra license fee for use of the SVCD logo, or it could be the the CDROM reading capabilities of the machine are not up to SVCD requirements. In your case I suspect it is the latter, though it appears to be borderline. In this case you are pretty much out of luck. Either re-encode to a lower bitrate or VCD standard, or buy a new DVD player that does support SVCD.
Sorry.
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
151MB mp4 file - with header problem?
By supermaster in forum RestorationReplies: 7Last Post: 6th Jan 2012, 08:52 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 16:21
