    Atlantic Canada
    Hi, I am looking for the instructions on how to frame serve from virtual dubbing or how to get rid of bad frames using v-dubbing mp3 freeze. Thanks
    Atlantic Canada
    what do you do after it says , bad frames found and logged?
    Atlantic Canada
    Please does no one out there have any time to help a not leagally blonde fix her avi's so she doesn't have to re download. I read what I could find and still dahh to me.
  4. Haven't frameserved before but try:
    http://www.vcdhelp.com/virtualdubframeserve.htm
    I also have never used the other prog you mentioned
  5. click on file badframes.log for the bad frames on drive C and then open or switch to vdubmp3freeze, select Edit Go To and copy the first bad frame and paste and click this sign [ at the bottom right hand of the program as your starting point and switch to badframes.log again and copy the last frame, switch to vdub and select Edit Go To and paste the frame. Click on the sign ] and hit DELETE on your keyboard. select STREAM COPY and SAVE AS for your new file.that's it.
    Atlantic Canada
    Thanks for your help, I am sure I could do that if I could find the badframes.log..where is this suppose to be?, I don't see it under file.
  7. Do a search of your computer (Start - Find - Files and Folders) and search for *.log This will find all the files that end with .log and then open the one you're looking for.
