Hi all,
I seem to be getting lotsa error when I use their internal tools to convert so can some1 pls kindly recommend a good software that can do it easily? I just want to import the audio files to DVD-lab so I can use em' in the menus and such.
Thanks in advance for the advice.
ffmpeggui can also convert to MP2 which is part of the DVD standard for PAL land only, but is likely to be OK in NTSC land on newer machines.Originally Posted by johns0There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks for the replies and advice fellas. I will give the ones recommended a try.
Have a good day.
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 16:34 -
MPEG2 Video with AC3 audio cannot convert to MP3 audio
By wenglock in forum ffmpegX general discussionReplies: 0Last Post: 7th Sep 2009, 22:52 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 20:07 -
Using WMP to convert Audio files on a cd to mp3
By jyeh74 in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2007, 16:32 -
Convert played audio to MP3?
By Algo in forum AudioReplies: 1Last Post: 13th May 2007, 13:43
