  1. Is there an easy way to to set the field order in Tmpgenc for encoding an avi source file obtained from backing up your average hollywood DVD movie?
  2. Lost Will Hay's Avatar
    Oct 2002
    Buggleskelly Railway St.
    Try this guide here, I constantly refer to it and for me it's the bible of TMPGEnc
    Will Hay
    tgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
  3. Thanks mate, I do already use that guide and your right it is a bible, I just wonderd if there was a short cut rather than going to all the effort of testing. I suppose I'm just being lazy!!
  4. Use TMPGEnc's Project Wizard.
    You'll find it on the File menu.
    After selecting the format you get to Project Wizard page 2.
    Load your video source and TMPGEnc will scan the source - if it's interlaced then it'll set the appropriate field order for you.
    Martin.
