Hello,
I have downloaded a couple of AVI files off the net which have been ripped from a DVD. My problem is the AVI's have the dvd commentary on them, as well as the normal audio (quieter)
I've tried moving the balance from left to right in WMP but it doesnt change the audio.
Is there a possibility I can stop the audio commentary while keeping the regualr audio channels?
Rob
Thanks for the reply
I've done that and for some reason both audio channels are playing the file without audio commentary, I suppose this means there are more than 2 audio channels on the file.
But how do I control (from within WMP) which audio channels play? Or other software if required.
Rob -
Also worth mentioning.
I've loaded the file through AVICodec, and it is saying I have 2 audio streams,
1. Audio : 19.76 MB, 128 Kbps, 48000 Hz, 2 channels, 0x55 = MP3 encoder, Supported
2. Audio : 12.34 MB, 80 Kbps, 48000 Hz, 2 channels, 0x55 = MP3 encoder, Supported
Any ideas?
Recording with commentary
By Cyber Akuma in forum Newbie / General discussionsReplies: 0Last Post: 8th Jul 2009, 18:45 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Commentary track
By AlanHK in forum AudioReplies: 10Last Post: 6th Nov 2008, 02:47 -
How to remove commentary track in AVI.NET?
By sads in forum DVD RippingReplies: 0Last Post: 23rd Oct 2008, 10:47 -
commentary
By tylerdurden in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 16:45
